1 - 2 of 2 Posts
I have a 2012 Ram 3500 4WD Crew Cab ST DUALLY (DRW).
I bought it used with 140,000 miles.
However, after spending almost 3 days trying to match up the 3 REAR MAIN driveshaft U-Joints for a DUALLY (DRW)-
Come to find out my driveshaft calls for SINGLE Rear Wheel U-Joints (SRW)
Is this normal or did someone put a different driveshaft in my truck at some point?
(I rebuilt both front and rear driveshafts using my home made horizontal hydraulic press =
A 1.5 ton bottle jack and a piece of a 20 inch wide "I" Beam.)
(Had to use a grinder to cut out part of the old Rear shaft joints...)
Automotive tire Road surface Asphalt Motor vehicle Bumper
Automotive tire Gas Cannon Cylinder Automotive wheel system
Automotive tire Asphalt Floor Gas Motor vehicle
Discussion Starter · #2 ·
I got them all done.
2 Moog's and 1 Spicer in the front axle (forget the numbers...)
The rear took 3 Spicer's 5-3206X
1 - 2 of 2 Posts
