1 - 8 of 8 Posts
i hooked up a new radio and need to have the rear sensor hooked up to the new system...does anyone know the wire and where to find it ?
or can i just tap into the wire coming off the rear sensors themselves ?
i hope im describing this clear enough ...
thanks
I'm asuming that you want to mute the radio when the park assist sensor detector alarms like the OEM radio head?
I might be wrong, but I believe that the connection is made throught the CAN bus. You might be able to find out from the wiring diagram for the truck.
Andy
Yes that wire is in the can bus. Its the solid green wire on the can bus or pac harness. It should go to the reverse gear input wire on your head unit. On my Pioneer it was violet/white wire.
Discussion Starter · #5 ·
can bus ,pac harness ?. i'm sorry where would i find these ...not very knowledgeable on wiring ....i also installed a pioneer so the wire may be the same .....
and yes i do i want to mute the radio when sensors are active ....
thank you all
The pac harness is the one you joined to the pioneer harness. Its the one with the canbus interface. (Behind the radio) Its likely the same as mine. Which head unit did you get?
1 - 8 of 8 Posts
