1 - 6 of 6 Posts
Anyone else have the rear window leaking at the top left and right corners?
The truck did this when it was younger but it was fixed by a company that specializes in that. We had a very healthy storm last night and it drenched the headliner on both sides of the truck. It's a huge annoyance having a 4 year old truck that won't stay dry on the inside. :smiledown: If it isn't too big of a job I want to remove the window completely clean the sealer and re seal properly.
Anyone done this themselves?
Are you sure it is not coming in from the third brake light at the top? There is a whole thread on this somewhere on the site. This is a common problem with these trucks. Mine did this and the leak came from the rear corners of the window. I opened up the third brake light and added a bead of silicone...problem solved...:smiley_thumbs_up:
I had that as well, and when I fixed the third brake light, the issue went away. The third brake light is likely the culprit of any rear window leak and wet storage carpet area...
i had the same problem and it is the third break light. i had taken it to the dealer 3 times and had it replaced 3 times. the last time lasted about a year and now ill see with the new one but i don't think they fixed the problem even tho they know all about it
1 - 6 of 6 Posts
