1 - 7 of 7 Posts
Ok so i over loaded my truck and gears are going bad so looking to up a bit to 3.92 anyone has an idea what parts i need and where to get them my truck is a 2012 dodge ram st 4.7 2wd
I would check for local wrecking yards and just get an entire rear end.
Unless you know how to set the gears up or are paying someone to set them up, a complete assembly is the easiest way to go.
Discussion Starter · #5 ·
Yes i have a guy that can set them up for me but hes really busy waiting on his call to get a price on the parts but wanted to see if i can find them to see if the price he gives me is reasonable or i can order them but like i said i dont know exactly what i need because ive seen the pinion and the geer but is that all i need?
Ring and pinion, pinion bearings, crush sleeve, possible pinion depth spacers, pinion nut, and I would replace the ring bolts, gear lube for 2 fills as I would change it after break in.
1 - 7 of 7 Posts
