1 - 5 of 5 Posts
Discussion Starter #1
I have a 1996 Dodge Ram 1500 with power door locks but no RKE module. Can I add a Factory RKE module w/remote(s) from a junker? Where is the RKE harness? Is there a sticky or link with more info on this? I've been through all the "go to the dealer", "buy an aftermarket...", and "get a good wiring diagram", "get a build sheet(which I have)" type links and discussions...but really this can't be brain surgery...these vehicles must have been shipped with a harness connector and simple procedure so the dealer could make a few bucks adding this feature!
I am also quite intrested for this option plus the heated mirrors, fog lights, and roof mounted console(compass, outside temp ect) for my '01 1500
Discussion Starter #3 (Edited)
Yes... that's a good point White Lightning! 1996 was the highest selling year for Rams to that point...and maybe even until today. There were 400,000 sold! There has got to be tons of info and cheap parts out there...somewhere...for all these dealer added accessories. My Build sheet is listed below, yet I can't seem to find a list of what all the sales codes are...or what precisely each included:
1996 Dodge Ram 1500 was equipped from the factory with the following:
Sales Code Description
*P1 Premium Cloth 40/20/40 Bench Seat
ADAP Light Group
ADJ Heavy Duty Service Group
AHC Trailer Tow Group
AJKP Convenience Group
AJPP Power Convenience Group
APDA Lower Two Tone Paint
ASPP SLT Decor Group
AWK Travel Convenience Group
BAZP 136 Amp Alternator
BCQP 750 Amp Maintenance Free Battery
BGJS Pwr Disc/Drum Rr Anti-Lock Brakes
BKAS 11x2 Rear Drum Brakes
CBEP 40/20/40 Split Bench Seat
CGTS Driver Air Bag Only
CHEP Deluxe Headliner
CKEP Front Seat Area Carpet
CLAP Front Floor Mats
CSRP Passenger Assist Handles
CUNP Overhead Console
DGB All 4-Speed Automatic Transmissions
DGTS 4-Spd. Automatic 46RE Transmission
DHAS Lock-Up Torque Converter
DMDS 3.55 Rear Axle Ratio
DRBS Corporate 9.25 LD Rear Axle
DSA Anti-Spin Differential Rear Axle
EAAC All Engines
EML 5.9L V8 MPI Engine
GACS Tinted Glass Windows
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GNKP Rear View Auto Dim Mirror
GNMP Passenger Side Sun Visor w/Mirror
GPPP Power 6 x 9 Bright Mirrors
GVBC All Vehicles W/Power Mirrors
HAAP Air Conditioning
HGAP Hood Insulation
HGBS Dash Liner Insulation
JAYP Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBP Dual Note Electric Horns
JJJP 12V Auxiliary Power Outlet
JPAP Power Windows
JPBP Power Locks
K17P STRIPE/BADGE/MOLDING
LAAP Ignition Time Delay Lamp
LBAP Map/Courtesy Lamp
LBCP Glove Box Lamp
LDAP Underhood Lamp
LMAS Halogen Headlamps
LPEP Cargo Lamp
MBFP Bright Rear Bumper
MCTP Bright Front Bumper
MDAP Front License Plate Bracket
MFDS Bright Grille
MHAS Black Windshield Moldings
MPBP Black Tailgate Applique
MWDS Removable Tailgate w/Caliper Latches
MXBS Front Air Dam
MXCP Front Bumper Sight Shields
NAA Federal Emissions
NBKS EVAP Control System
NFWS 26 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHMP Speed Control
NMCP Heavy Duty Engine Cooling
PGFA Emerald Green Pearl Coat
QFAA Prairie Pearl Coat
RAAC All Radio Equipped Vehicles
RASP AM/FM Cassette Radio
RCDP 4 Speakers
RDDP Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCVP Leather Wrapped Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SUAP Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TYFP P245/75R16C BSW All Season Tires
TZAP Goodyear Brand Tires
WLBS Steel Spare Wheel
WNDP 16X7.0 Cast Aluminum Wheels
XBSS Pickup Box
XCMS Vendor Painted Cargo Box
YAAS Build To U.S. Mkt. Specifications
YEP Manuf Statement of Origin
In addition, we have updated the name and address mentioned in your email as the current owner of the vehicle.
Thank you for being a part of Ram, have a nice day!
Sincerely,
Alyssa
Customer Service Representative
Ram Customer Assistance Center
My 05 came equipped with power locks but no module. I purchased one off ebay with 2 key fobs and installed it myself. The module simply plugs into the back of the instrument panel and then needs to be programmed. I found a local locksmith with a scanner tool that programmed it for $10. All in all I have $45 into mine.
I actually have a spare module out of a 2003 truck but no idea if it would work for a 96 or not.
Premium Member
2002 was a mid year change over, from what i have read, it may or may not make a difference when trying to find wire harnesses & modules
199? - 2002
2002 - 2008
1 - 5 of 5 Posts
