1 - 8 of 8 Posts
Discussion Starter #1
Purchased a derale oil filter relocate kit for my 13 2500 5.7 hemi. I’d like to add a small oil cooler but the oil lines for the relocate are 1/2” ID however the oil cooler barb fittings on the cooler accept 3/8” ID hose. Will this be too restrictive?
I would not think that would be a good thing. I would do some research and see if the part number you have matches what shows up on manufactures web site.
Super Moderator
19 Ram 1500 Big Horn Sport 5.7 Hemi 4X4 QC
Wow what a helpful site. ✌🏻
Just to let you know, sometimes it may take a while to get an answer. It is not instantaneous. If someone has an answer, they will post it. Otherwise, no answer means they probably didn't didn't have an answer for you. Be patient.
I just now saw your thread,and I’ve done the oil cooler thing on a corvette(dual ones) and I should do the same as you are on my pita 19 hemi. Anyway a search I did found CX racing has a 1/2”npt oil cooler,no fan though so it’s possible ,and fans on them are a must.
1 - 8 of 8 Posts
