Thank you all in advance 1st Post This forum-
Issue; Had the Valve seat issue..
Replaced entire engine with Running take out
Using a Snap on Code reader Cleared all codes
cycle key numerous times
Go to start battery "acted" dead -Jumper from adjacent car
Go to start, Turn Key
Engine bumps 1 cycle1 revolution
Doesn't continue to Crank.. just stops
Throws code (will need to update lost code) But indicated as..Vehicle NOT in park
Side note: used the manual disengage to move truck off tow truck..
Release manual override while plugged in & code reader indicated not reset
locked back in place code cleared
We didn't touch the Trans or any wiring to Trans that we know of. Today's task recheck all harness connectors ensure grounds are good ensure battery is fully charged
get all the codes that seem pertinent and post on here
Thoughts-
Thoughts-
