Hello all, I am in desperate need of some help.
I searched this forum before deciding to replace my water pump.
I replaced the Water Pump, Clutch fan, thermostat and belt because the water pump was leaking pretty bad in the driveway. I decided to do all of the others while I was in there.
Everything went together just fine. The problem is that now when I test drive it, the truck Revs up to like 2K-3K RPMs before shifting to second.
I'm not sure where to begin to fix this.
I thought maybe there was air in the coolant lines.
I filled with coolant and turned the heat on max and the fan on high.
Then let the truck run for about 15-20 minutes. Let it sit and then topped off with coolant (wasn't a lot to top off to be honest.)
I also thought maybe it is Air Filter related (sorry if I'm way off, I don't have a lot of diagnostic skills at all. I usually get someone to diagnose for me and then I do the repair.) Back to why I thought maybe it was Air filter related....
I have the K&N air filter and in the middle of the tube (don't know technical name) between the Engine and the filter there appears to be a sensor of some sort that is inserted into a drilled hole in the plastic tube. The grommet around this "sensor" was torn and the sensor did not seal there very well so in messing with it, I made it even worse. I then put electrical tape wrapped around the tube and the sensor in an effort to seal it back up. I believe I did an ok job, but not sure if this could be related to my rev problem. Also when the truck is running and just after cutting off, I can hear a sucking sound ?? coming from around the actual K&N Filter like maybe there is something there. The filter isn't completely sealed though is it? I mean it sucks in air an filters it right?
I'm sorry I don't help much I just really don't know were to begin.
Any help would be greatly apreciated.
Best Regards,
Blain
Best Regards,
Blain
