1 - 3 of 3 Posts
I am replacing the starter on my 1999 Ram 1500 and I have run into a little problem , I can't seem to be able to get to the bolt on the top & was wondering if there was an easy way to get to it ? It looks as if I have to remove the exhaust pipe but don't want to if I don't have to .
G
You should not have to. The manual says you may run into some interference from the transmission cooling lines. If so, just slide the cooler tube bracket forward enough to get access to the top bolt.
1 - 3 of 3 Posts
