RHR 2.120 update (untested)
1844 6
Found this on the Mygig forum.
I have not loadeed it yet, but others have and seems fine.
http://mofv.com/mygig/BBS/viewtopic.php?f=9&t=5447
1 - 7 of 7 Posts
Hmm, Am I correct in thinking this update would already be in place for 2012 Vehicles?
Possibly...depends on the build date...some newer ones could even have a newer update than the 2.120. Easy way to find out...from your menu, go to "system setup", then "system information" and it will tell you what software application you're running.
· Read Only
I bought my 2012 Loghorn on Dec. 16 and it was 2.110. I upgraded shortly after I bought it thinking it would fix the NAV problems I am dealing with but it never made a difference.
The NAV routed an extra 300 kms out of the way on a 450 km trip. Latest report was that MyGig enhanced GPS on the 730N RHR radio only used verified raod data from NAVTEQ instead of all the roads in the data.
It might work well in cities but it really sucks int he rural areas of the country. I will not rest until this NAV system works as well as a Garmin or Magellen that can be bought and mounted on the dash.
Really not happy with the NAV system on these MyGig systems. i have a post on MyGig forums as well as on here about the issue.
Discussion Starter · #6 ·
I just checked mine, and It was buillt Dec 15/11 and its running version 2.116. So there will be no real consistancy in versions. Not sure exactly what the update contains, im stil researching that. Going to try installing it tonight though.
1 - 7 of 7 Posts
