1 - 4 of 4 Posts
Discussion Starter #1
I have some road paint on the right rear fender. The paint that they use for the stripes etc. I tried a clay bar and it got the little specs but not the bigger chunks. Does anyone recommend anything else?
Thanks.
Premium Member
in California if you drive across a new paint stripe
you submit a claim, especially if you don't see a striping truck
the State pays to clean your vehicle off
i know because i worked for the California Dept. of Transportation
i can't see any State doing it differently
You may need to try a solvent, assuming the road paint hasn't been removed already. I would use the solvent [paint thiner, Tarminator, etc] and use a plastic razor blade to remove it from the paint. Obviously flushing the paint after using the solvent too.
1 - 4 of 4 Posts
