1 - 5 of 5 Posts
I have a 2011 Ram 1500 Laramie. I took the running boards off to sell, but when someone came to buy them we discovered that the receiving nuts on the frame seem to be pressed in like a rivet. His truck has hex shaped holes but no threads. Any ideas?
Be sure to get the correct size "hex shaped" rivnuts. The hex keeps them from spinning. If the auto p[arts store does not have them the Ram dealer should. They can be easily installed with a bolt, washer, and nut. No special tools needed. Someone installed them in your truck before the boards were mounted ether at the factory or by the owner.
  • Like
Reactions: askon57
Were you able to locate the Rivnuts?
1 - 5 of 5 Posts
