So, I pick up the pickup on Saturday. '03 Laramie 4x4 Crew Cab.
Guy said body work and repaint was done not long ago, not sure how well or by who, feels pretty solid but already can see some rust bubbles at the cab corners. Has the fender flares so couldn't see under there, but apparently a newer box was installed as well.
I plan to do some weekend repairs myself, and eventually repaint myself.
Looking for some ideas regarding rustproofing since I live in Ontario where cars simply do not last.
I know the basics, keep it clean, wax, mud flaps though with flares not needed...
I'm looking for other things to do. Like pulling the interior out around the cab corners and maybe spraying with something, or drilling holes in the wheel wells to get a spray nozzel up there to spray in. Is it better to use rubberized spray? that non-paintable undercoating that's sorta tar like? get a spray gun and use the old oil after oil changes? all of the above? For the cab corners and rocker panels, maybe using expanding foam (closed-cell type that doesn't suck up water).
For now I want to do some basics... but if/when I redo the body work and paint, I definitely want to rust proof this as best as I can beyond just a wash/wax 2x a year and underspray in Fall. Especially since having looked for used ones the past month... the cab corners and around the wheels on most of these are just gone.
Thanks
Thanks
