1 - 3 of 3 Posts
So I recently purchased a 2014 Ram 1500 and the only major problem I have with it is the hitch mount looks horrible, a lot of surface rust. Has anyone restored their hitch mount from a rusty condition?
I'd like to remove the rust and repaint it black so match the truck. Anyone done this and if so could you let me know what you used? Thanks!!
Super Moderator
Hit it with some gun oil and a wire wheel. Then the rust will be gone and you can degrease it and you can paint it or whatever
Similar to above, I hit mine with a 3m scuff pad to knock off the surface rust and touched it up with RustOleum Auto Enamel from Home Depot. I just had a bit of surface rust though - depending on how much rust you may require more prep work.
1 - 3 of 3 Posts
