Rut Roh Engine check light, #2 cyl misfiring
824 4
My beloved 2010 Ram 1500 4x4 is in the shop today for the first time in 27,000 miles :( Started idling rough yesterday out of the blue, they worked on it a couple hours this morning, new plug new coil did not fix it, still misfiring on #2. So I wait...:naughty: man I was hoping this was going to be something simple.
Turns out there are also 2 recalls they are fixing, tie rod ends and Heat/AC module activator/reprogramming.
1 - 5 of 5 Posts
I believe it's only a "recall" if it's a safety issue, and you will be notified about it. If it's not a safety issue it's called something else (rapid response bulletin? and there are others as well) and I don't think they have to notify you, they just are supposed to update/fix when the vehicle is in.
1 - 5 of 5 Posts
