hey guys, i have a noisy rear end when i step on the gas, so bad rack and pinion. there is a 3.55/9.25 4x2 rear end at the local salvage yard. its an '03 and i have an '05. so i guess i have two questions - can i swap a 4x2 rear end in place of a 4x4 rear axle assembly? and second, can i swap the '03 into the '05. i read online that spline counts can vary by year for fords for example, but it sounds like you generally can swap 4x2 rear differential assemblys into 4x4s. just wanted to run it past the forum and make sure i know of any other variables i need to be aware of. thanks
