That's a bit of a drive LOL. See my previous post. I will see if I can find the link for you. It's a pretty easy process.Im on the East Coast Ft Lauderdale Area
I could never get the uconnect site to work. Always got error messageThis is a pretty good step by step, I would have the truck running for this but that is me. https://www.youtube.com/watch?v=7n2kavHJYz8
This is the link to the file you need... https://rsur.extra.chrysler.com/rsur/Uconnect.do
Thanks I just read that guess ill need to get a 32gbKeep in mind that the largest capacity that Uconnect officially supports is 32 gb. I have a 64 gb SanDisk SD card that initially gave me no problems. Once I got it about half full (5700 mp3s) it got very flakey. At first restarting my Ram would get it to read. As time went on, it took more restarts, sometimes taking 4-8 hours before it would read again. I gave up with it and put my 32 gb card back in which has given me no problems. Also, the file system that it is formated to makes a difference. The default exfat for 64gb won't work. Try formatting it to fat 32.
This plus there are sporadic issues with Class 10 sd cards, which your Ultra most likely is. Others have had much better luck with lower class cards like a Class 4. I currently use 3 Sandisk 16gb Class 4 cards and have no issues.... other than it not reading subfolders in order. For example, it should read the folders like this:Thanks I just read that guess ill need to get a 32gb
I`am using IE 11. I turned off protected mode I still get error message. I was able to download the 14.25.5 from a download site. I could try my daughters Mac to see if it works.Once you go the the above site this will help in the download as to what you should be looking for:
http://ramforumz.com/album.php?albumid=3805
As for album art on the SD card, that is not a problem, I even remove the album art that comes with the music and put in my own photos.
Here is a photo tutorial I posted awhile back:
http://www.ramforumz.com/showthread.php?t=175930&highlight=album
