1 - 3 of 3 Posts
Any Dodge gurus out here? 2015 ram 3500 with service 4 wheel drive system error. Two faults in the module C147B front axle disconnect sensor circuit performance and C1464 front axle disconnect control circuit low. I'm thinking the actuator motor but would welcome some input on testing the circuit. Specifically what voltages to expect at the actuator connector and any other Insight you would be able to provide. Appreciate it y'all.
My 2015 did the same thing, I replaced the front axle lock control unit, no luck. Have you resolved your problem?
1 - 3 of 3 Posts
