I have a 2014 2500 Laramie and am having an issue with the signal lights.
The triple flash when pressing the lever only works when signalling left. If you lightly press the lever to signal right it will only flash the signal while the lever is held on. If I simply press the lever to signal left, however, it flashes the signal light three times even though the lever has been released.
According to the manual it should triple flash in both directions:
"Lane Change Assist
Tap the lever up or down once, without moving beyond
the detent, and the turn signal (right or left) will flash
three times then automatically turn off."
Is anyone else experiencing this issue?
"Lane Change Assist
