1 - 7 of 7 Posts
As long as it's a defect, and not a nail... I'm sure it is.
Just for giggles... spray some soapy water around, and in the valve stem, and see if it's leaking. (The core may just need to be tightened, or replaced)
You should have a tire warranty from the tire mfg. If not take it to a shop that sells your tire brand and buy a road hazard plan. It's like $15 a tire and worth every penny.
Discussion Starter · #5 ·
Found it. Ran over some staples. Prob from home depot or lumber yard. 2-3 of them in a small spot. Pulled them out. I i use that sprat stuff? Is that safe.with the sensors? Don't know if I can use a patch. If it's multiple holes in a small area
· Premium Member
If you used anything like the Fix-a-Flat stuff
You need to have the tire taken off & everything washed out good
That goop is for emergency repair only !!
When you take the tire in for permanent repair, you need to tell the tire shop that you used Fix-a-Flat, so they can thoroughly wash it out
read the instructions in the kit :)
http://www.fixaflat.com/faq/
Tell them you used Fix-a-Flat or something similar. They get pissed off when the stuff gets all over the equipment and them.
Greg
1 - 7 of 7 Posts
