1 - 15 of 15 Posts
This should be interesting with multitude of answers...:4-dontknow:
Anyways, I do a lot of highway driving. I would say probably 95% of my driving is highway at speeds of 100 - 120 kph. I travel each way about 1200kms every 2 weeks and the rest of the time my truck pretty much sits and waits for me. I go by the onboard computer to tell me when to change my oil. Oh btw its a 1500 Sport, 5.7.
Would it be better to use a synthetic oil, and higher end filter with this type of driving?
What are a couple of the better oil brands to use?
What would be a better type of filter brand to use?
Winter is soon coming also. The temps get to -35c on average. Should I go with a different oil then recommended when the temperature gets lower?
With the very low temperatures should I be using something different in the 4-wheel drive differential etc?
Sorry for what seems like dumb questions but I am trying to get a good idea as to what I need as I am no mechanic.
Not a dumb question!
Standard Dino oil is sufficient and there are plenty of engines that lived long lives on that. I've even heard people who work at Blackstone (the oil analysis lab) say they just use Dino because it is inexpensive and works very well within normal oil change intervals.
But I like to have a little cushion so I run synthetic. It gives me some peace of mind that if for some reason I can't do an oil change right when it's due it's no worry. Also it gives me peace of mind with these longer oil change intervals the vehicles are suggesting. Lastly, I'm in Michigan and synthetic has much better cold flow properties. I do feel there is a very tangible advantage to synthetic when temps drop below 0 Fahrenheit.
Ultimately it's your call. If money is tight, run a good standard oil/filter and rest easy that your engine will live a long life. If you can afford it, run synthetic for more peace of mind.
Both valid and excellent responses. The only point I woud ad is, regardless of which way you go with oil, always use a high quality filter. To use a cheaper poorly made oil filter is false economy.
Good filter is important for sure. No Fram's for me.
I buy bulk WIX from FleetFilter. Only had one issue where the transmission filter was made in China and the holes into the filter weren't the same. I had higher tranny temp and I believe it was because the tranny fluid was restricted.
Mopar, Napa, Wix, Mobil, Purolator, would be my choices from what I remember.
Correct my list if faulty.
K&N oil filter here ( 14 hemi = K&N HP-1017) I use OEM oil filter when K&N is not available.
I switched to Pennzoil Platinum 5W20 (my owners manual says pennzoil is recommended)
(Walmart @ $22.00 in the 5qt jug, i usually just buy 2 jugs, in qt form its $8 per qt = OUCH..!)
Stay away from FRAM oil filters, word is they`re junk. Many complaints out there about them.
Most high end brand name synthetic oils are good, so pick your weapon of choice.
EDIT:
The 5.7 hemi with MDS, has to have the 5W20 to make the MDS work properly.
Sub zero temps, maybe use 0W20 synthetics... should be fine.
I run Redline 5w-20 synthetic oil in my 2014 Ram with the Pentastar V-6 and I use the OEM oil filter.
I also follow the change it at 10,000 miles or one year.
Redline is expensive oil but it is also a Group 5 synthetic and I like the advantages that a group 5 synthetic provides for better ware protection.Group 5 synthetics are made up of esters while Group 4 synthetics are made up of PAO's.
Ester Chemistry
In many ways esters are very similar to the more commonly known and used synthetic hydrocarbons or PAOs. Like PAOs, esters are synthesized from relatively pure and simple starting materials to produce predetermined molecular structures designed specifically for high performance lubrication. Both types of synthetic basestocks are primarily branched hydrocarbons which are thermally stable, have high viscosity indices, and lack the undesirable and unstable impurities found in conventional petroleum based oils. The primary structural difference between esters and PAOs is the presence of oxygen in the hydrocarbon molecules in the form of multiple ester linkages (COOR) which impart polarity to the molecules. This polarity affects the way esters behave as lubricants in the following ways:
Volatility: The polarity of the ester molecules causes them to be attracted to one another and this intermolecular attraction requires more energy (heat) for the esters to transfer from a liquid to a gaseous state. Therefore, at a given molecular weight or viscosity, the esters will exhibit a lower vapor pressure which translates into a higher flash point and a lower rate of evaporation for the lubricant. Generally speaking, the more ester linkages in a specific ester, the higher its flash point and the lower its volatility.
Lubricity: Polarity also causes the ester molecules to be attracted to positively charged metal surfaces. As a result, the molecules tend to line up on the metal surface creating a film which requires additional energy (load) to wipe them off. The result is a stronger film which translates into higher lubricity and lower energy consumption in lubricant applications.
Detergency/Dispersency: The polar nature of esters also makes them good solvents and dispersants. This allows the esters to solubilize or disperse oil degradation by-products which might otherwise be deposited as varnish or sludge, and translates into cleaner operation and improved additive solubility in the final lubricant.
Biodegradability: While stable against oxidative and thermal breakdown, the ester linkage provides a vulnerable site for microbes to begin their work of biodegrading the ester molecule. This translates into very high biodegradability rates for ester lubricants and allows more environmentally friendly products to be formulated.
Another important difference between esters and PAOs is the incredible versatility in the design of ester molecules due to the high number of commercially available acids and alcohols from which to choose. For example, if one is seeking a 6 cSt synthetic basestock, the choices available with PAOs are a straight cut 6 cSt or a “dumbbell” blend of a lighter and heavier PAO. In either case, the properties of the resulting basestock are essentially the same. With esters, literally dozens of 6 cSt products can be designed each with a different chemical structure selected for the specific desired property. This allows the “ester engineer” to custom design the structure of the ester molecules to an optimized set of properties determined by the end customer or application. The performance properties that can be varied in ester design include viscosity, viscosity index, volatility, high temperature coking tendencies, biodegradability, lubricity, hydrolytic stability, additive solubility, and seal compatibility.
I'm also from Kamloops. Lordco has the Pennzoil 5W20 Ultra Synthetic on sale, $7 liter. You can't find a better factory recommended oil and it will do very well in cold weather (Fort Mac?). The Notre Dame store has a huge display in the center of the store. Oil filters; I would stick with Mopar or a Wix 57060XP that West Can Auto parts carries or can bring in. They are also on Notre Dame Dr. All the features of a premium oil filter and not a lot of money. With the kind of driving you are doing, I would push the 15,000km max interval for oil changes. Your computer will be close to that. The tranny and diff's are fine, no need to change these.
I always use either Penzoil or Mobile 1 0w 20 weight and a Motorcraft 820s filter. I go with the zero weight because once in awhile I have to make a quick trip to North Dakota in the winter. The xtra "5" lower makes a huge difference in cold weather (below zero) starting. Also like the Motorcraft filter. They are good quality and stocked at Walmart for less than 4 bucks. I change every 4000 miles and have Fumoto valve in place of the oil pan plug. Best $30 you can ever spend.
Ester Chemistry
You really ought to give credit to the author of the paragraphs in your post, when you copy and paste, or provide a link, otherwise your posts might be confused by some, as Plagiarism :shy:
I believe the author above would be T. G. Schaefer (Tom NJ) on "Bob is the oil guy"
1 - 15 of 15 Posts
