1 - 4 of 4 Posts
Discussion Starter #1
I am trying to replace the spark plugs in my 98 Ram and am having difficulty removing them because of the steel sleeves that are around them. I blew a lot of crud out from the sleeve and from around the plugs but still cannot get the socket over the plug hex.
I cannot remove the sleeves, I sprayed WD40 into the sleeves and around the plugs but still no help...any ideas?
You may have to scrape at the crud with a small thin screw driver and continue to blow it out until the socket will fit. :4-dontknow:
Dy you have a sparkplug socket? They are a little thinner than a normal socket.
1 - 4 of 4 Posts
