1 - 8 of 8 Posts
Coming up on 30k, and manual reccommends spark plugs and tire rotation. what spark plugs would yall recommend that give ultimate performance?
Plugs
The best plugs for your application really are the dealer copper plugs. Anything else and you are risking a rough idle or damage.
Stick with the OEM type copper plugs. The Hemi is not happy with the fancy plugs.
If you DIY this, make sure you use some anti-seize on the plugs and dielectric grease on the boots. :)
i have a 08 and just changed my spark plugs at 52,000 and they looked pretty nasty. I bought the truck with 40,000 miles on it and it just proves you cant assume anything with a used vehicle.
Plugs
When I changed mine at 32,000 my plugs looked like it was needed but I have heard that people not changing them till 60,000. I don't suggest it but I enjoy working on my truck and not paying someone labor.
Has anyone looked at their plugs at 30K and seen any reason they wouldn't go to 50K easily?
I had my plugs changed at 32,000 and they were worn a bit but not much. I will stick to the 30,000 change interval just because it can't hurt and I do the work myself so its not that expensive.
I just changed mine at 68,000 kms with Autolite DPs. Couldn't find the OEM Champs anywhere around here..NFalls Ontario and NY..Oh well. Dealer here in Cda wanted $10.50 per plug x 16= WTF... got em at Autozone in NFalls NY for $4.50 per, plus a $2.00 per plug mail in rebate. How can they do that here in the great white north??
Anyways, was a relatively easy change except for the 2 on each side closest to the firewall.
1 - 8 of 8 Posts
