1 - 5 of 5 Posts
I'd like to get the Infinity 6x9 Kappa coaxils for the front doors of my 2011. Is there any company out there that makes the spacer that perfectly fits and makes them capable of putting them in the front doors? I'd really like 6x9's in the front. As far as making one, I guess I could try but would rather just buy one. Thanks Everybody!
Cut some oval rings out of MDF and coat them in spray can bedliner so that moisture doesn't cause them to fall apart in the doors.
Would you know how thick I would have to make it?
That depends on the mounting depth of your speakers. Set both new and stock speakers on a flat surface and measure the difference in depth and cut the wood accordingly. If the wood does not sit flat on the door skin add some rope caulk to seal up the gaps.
1 - 5 of 5 Posts
