Hey all, I ordered a set of Spec-D OEM fog lights for my '02 Ram a couple weeks ago. Upon arrival I noticed that it was missing the bezels and the mounting screws/bolts. I called Autoanything and they said they would contact the manufacturer. A week later (today) they finally told me they have the parts on the way.
Did I mention the kit also didn't come with instructions? I am as newbie as it comes with electrical work, although I did get a pair of offroad lights installed a couple weeks ago. So I was looking at the fog lights to make sure everything makes sense, and I can figure out everything except where one wire should go. Starting from the switch to turn them on/off:
-On/off switch in cab
--> Plug-in, with 3 wires heading toward light harness
---> White wire leads to the light harness
---> Black wire is a ground
---> Red wire that has just a bare end on it
The red wire is what I can't figure out where it should go. The light harness has a wire to go to the battery, and a ground wire. Where is this wire supposed to go?
Also, an issue I had while installing my offroad lights was I could not find a way through the firewall. I worked around it by just routing the wire in through the door but I don't want a bunch of wires doing that. Is there somewhere that I missed? I looked for a good 30 minutes and could not find any way through. I would like to at least run the fog light wires the correct way.
