1 - 4 of 4 Posts
2020 Ram Big Horn 1500 5.7 HEMI
Discussion Starter #1
Adding a 2" level lift to the front of my 2020 Ram and updating tires to 33". Anyone do this and will it be necessary to re-calibrate speedometer or will the difference in tire size be negligible.
What tire do you have now? My 2019 Ram 1500 Classic Laramie is already a 33 inch tire P275/60R20.
Impossible to answer your question without knowing your current tire size to know how big it is.
What RaceHillFarms said. You already had 33" tires if your profile is correct and you have a 2020 1500 Big Horn so no calibration is necessary.
Search your phone's app store for Speedbot. It is a really good GPS speedometer that you can use to judge how far if any your vehicle speedometer is off and whether you need to have it adjusted.
Hope this Helps.
Only Cover Your Ram With A Factory Backed Ram Extended Warranty.
Buy Direct And Save www.Chrysler-Factory-Warranty.com
1 - 4 of 4 Posts
