1 - 10 of 10 Posts
Discussion Starter #1
Well I finally got up the nerve to start my box build for my truck. So far so good. Im putting a 8'' Kicker L7 under my rear seat on the passenger side. Just so I can have one side for storage and one side for play. I should be getting my subwoofer in today so I can make a few more cuts and hopefully start screwing it all together later this week. we'll see what kind of week Ill have a work. I started with the storage hole and have three sides made. Ill be sure to take pics along the way and post them one I start screwing it all together.
Be sure to take some photos so we can see what and how you are doin things!
I look forward to seeing what you did. Im sure it will come out awesome!!
Tim
And there is likely enough volumetric space to build the cabinet the right size for that driver. Good choice!
Sounds like a good build man, just out of curiosity are you doing a fiber or MDF box? or a combo? Custom molded boxes / custom built ones are always SOOO much better for sound resonance than prefab boxes, even ones meant for a specific vehicle.
And I'll second CustomShirts, give us pics!
Discussion Starter #5
Im making it out of 3/4'' MDF. Kickers website said that the 8''L7 needs between .33 and .75 cu ft of space for a sealed box and with my calculations Ill have around .48 roughly. (and thats the inside of the box with the subwoofer dropped in)
:smileup:Sounds great..........looking forward to thee finished product.
You'll definately have to post some pics and info on your build. I just got a 10" RF to drop in under my rear seat. I was trying to get it in under the driver's side rear because I don't want to lose my "mud tray" on the passenger side. However, I'm struggling to get everything in just right -- got a friend that does a lot of fiberglass work, so I'm thinking that something with a MDF frame and fiberglass body might be in the future and would give me a little more air space.
Discussion Starter #8
Well it took awhile to find the cable for my camera but here are some pics I took during and also of a semi finished product. I decided to cover the box with gray vinyl. I still have to trim it up a little but I got excited about hearing it so I just dropped it in.
box design is great but why particle board? MDF Is the one and only way to do boxs....but just a suggestion if you do keep particle board poly urethane the inside and out to atleast get it sealed
I agree completely, based solely on personal experience.....or was that a consequence ?!? Hate to say this after all the work you have done, but IF the box doesn't crack/shatter/flex/warp/splinter/etc., then it will sound rather boomy/dull/loose/etc. MDF is a fabulous material for the application. It's only real enemy is water, but even there, it's better than particle board.
Sorry for the bad news, but I so really like what I see, and really want you to get the sound quality you deserve after all that work. :smileup:
1 - 10 of 10 Posts
