1 - 2 of 2 Posts
I have a 2000 Ram 3500 with a Cummins and a 6 speed, it has quit starting with the key switch, if I jump the solenoid terminal to the battery the starter runs and starts the engine. What should I look for to correct this issue?
Thanking you all in advance for your advice,
David
when you cycle the ignition switch (key) are you getting power to the starter solenoid? If answer is yes, then you have a bad solenoid, if the answer is no, then you have either a bad ignition switch, broken ignition switch actuator rod, or bad connections/broken wires.
1 - 2 of 2 Posts
