1 - 10 of 10 Posts
Hello everyone, this is actually my first post on the forum, and I tried looking up to see if any recent similar threads existed and did not find any, so if they do, please feel free to redirect me.
As a Bracket racer, I decided to hop in my 2018 Ram 1500 quad cab and see what it could do quarter mile wise. I was extremely surprised by the performance. The truck is absolutely bone stock, and the only thing I did when racing it was pull the air filter out. After multiple passes down the strip, and I mean like 35-40 in a few weeks, my best pass was a 14.26 at 96mph with a 2.042 60ft. Believe it or not the truck is about 3-4 tenths faster in 4wd and launching at 1500 rpm.
What has everyone else achieved with their STOCK Rams? Most other people I've talked to have struggled to go under 14.5s stock, so just curious to see how we've all done.
Thanks!
2014 345ci 8hp70 44-44 3.92 Truetrac NX Express Comp Greene Racing
Seeing as regular cab R/Ts go high 13s at best, that’s quick for a QC.
What’s your DA?
wow, 14.2x is smokin' for a QC 4x4 !
your experience at the strip certainly helped ! ;)
the quickest 'stock' Gen4 non-R/T that I recall reading about is a 13.9x from a base tradesman RC 2wd ..
Super Moderator
These are about a 14 second truck stock, and usually in the high 14s, so you are doing very well. I don't race mine FWIW.
The fastest time I've seen for a cam only 4th gen was an 11, and that was an RCSB with a Moe's HPT cam
My old 2014 RCLB 4x2 went 13.90 stock 3.55s,4.56s went 13.20s , the SRT392 NON-NDS can went 12.90s, then the 428CI 6.4 stroker, went 11.60s with a comp cams 274, and then fried the 65rfe.
the new to me 2014 RCLB 4x2 went 13.85 last Wednesday at test and tune.....not sure if this
With brutal launches due to the mud tires I had on it I ran a 15.45, the 60' was 2.6 something. Also in 4000+da which sucks. I put a set of nitto 420's on it since then, I think I'd be lucky to see high 14's. That's the 8 speed with 3.92 gears, edge pulsar, vararam, 87mm throttle body and a muffler/res delete.
Discussion Starter · #8 ·
Update: Was able to best it by .02 to the tune of a 14.24 at just under 97mph. I have to say, man do I love this truck. Not only is it fast, but it gets 23mpgs cruising, and I've put a 28ft enclosed trailer with a 3600lb race car behind it and it towed like a champ!
What rear end do you have? 3.21 or 3.92?
1 - 10 of 10 Posts
