Hey all - Stripped spark plug threads in the head, looking for advice, thanks in advance.
Background - I have an '03 RAM 1500 with the minivan engine (3.7L V6), 150k miles. Noticed a knocking sound, pulled the code, misfire on cylinder 6 (rear passenger side). Found stripped spark plug threads in the head on cylinder 6. Spark plug was completely loose and had been getting shot into the coil pack. One deepest thread is still intact (I could thread an adapter for a compression checker into them) but the threads on the spark plug don't reach that deep. Assuming a previous owner had over-torqued the plug in the aluminum head, who knows.
Here's the question - Anyone have experience with this repair? Did you take the head off or were you able to helicoil it in situ? If in situ, which helicoil kit did you use that offered sufficient length to get down to the spark plug threads and also allowed clearance to work in the limited space? Any other tips (things to remove for better access, how to keep the hole square, don't even try it without removing the head LOL, etc). Keep in mind this is the back cylinder and has limited access.
Thanks all
Thanks all
