HI,
so today, suddenly truck wont start, 2016 Ram1500 sport 5.7. Worked fine an hour earlier, but now the gauges will click and the fan will try to start, dash showed 'press clutch to start' (its auto), though that seems gone now. Dash also says service electronic brake system, abs system, trailer brake system. It does need and oil change and the rear brakes are toast ( which is why I had driven it earlier, to get rotors and pads) could this be causing the issue?
Also the door locks only work randomly and the front window buttons wont open front windows, but the rear ones and real slider work.
I did check the battery with a volt meter, it's at 12v, terminals are clean and tight.
