1 - 3 of 3 Posts
Discussion Starter #1
Recently put spyder headlight assembly with halo rings on my 2013 Dodge Ram..a day later my system low voltage warning came up..my question is do I need to put a stronger alternator/battery or is there a different solution than putting my old headlights back in to fix my problem?
those Lights do not require more then the stock system supplies, the battery may just be bad. how old is it ,get it load tested to be sure.
1 - 3 of 3 Posts
