1 - 4 of 4 Posts
I have a 2017 ram 1500 and my tail lights went out on me. I checked the fuses and the bulbs and they were good. My brake lights do work when I hit the brakes. Has anyone ran into this problem before?
So your brake lights work, but not your running lights. You’ve already checked what I was going to suggest.
I'm only going from memory and don't have the truck anymore to tell you which one it is, but I had the same problem on my 2013 Ram 1500 and it's not the fuse that you think it is.
If memory serves it was a 20amp fuse (a blue cubed one), and the only place that I could ever get them was from my dealer.
You are probably looking at one of the the red 10 amp fuses or the yellow 15 amp fuse, but it's not that.
Double check your fuse box manual, and you will be surprised to see another one listed.
If I can find the fuse in my garage I will take a picture and post it back up.
1 - 4 of 4 Posts
