any opinions on what i should do to instal a tailgate light bar in 0 degree celsius weather? i know its recommended for 15 but thats going to be a couple month lol, so any opinions? heat up the area with a blow drier heat up the tape?
what brand of bar do you have? some brands have spots to screw right into the sheet metal. My gf originally ordered a recon but couldnt get it due to back orders so she got a rampage bar but it cant be mounted with screws.well i tried it, and this is actually my second attempt at it, and both times was complete failure, the weather was +1 today and had a propane heater and a blow drier going so i don't think the weather was to much of a problem, but it seems like the light bar just won't fit flat it pushes out on the very edges where sheet metal meets and cause the second tape push out preventing t from sticking how are people putting these on their 4th gen rams are the 12 different or what. i am seriously contemplating just getting rid of the light bar i can't seem to make it work
mine has the 5 sticky things as well, not sure if that would provide enough surface area on the sheet metal though.... I think when I do mine I am going to run a bead of silicone around the edge of the entire bar stop any chance of water and salt from getting behind. good luck with a reinstall! post some pics if you get it oni have the recon fire ice one it has 5 sticky mounts that are out further from the light itself if that makes sense
