1 - 4 of 4 Posts
I have 03 ram slt 4x4 quad, factory 20" rims, currently have 275/60/20 goodyear wrangler sra. lifted front end 2" with torsion bar bolt adjustment.
now I feel like my tires are too damn small.
looking not so much for wider, but want a taller tire, do not want to replace wheels, they look good. a little wider is fine, but I really just want to fill more of wheel well. wider tines will mean worse mileage, right?
what size do you guys recommend with stock wheels.
Wheel and Tire setup
I just installed a set of 295/60R20 Toyo Open Country ATII. I installed them on a set of Fuel Maverick Rims that are 20x9 0 offset. You could achieve the same spacing with the factory rims by adding a hubcentric spacer. Here's a few pics of my new setup:
https://imageshack.com/i/p1IyM790j
https://imageshack.com/i/iqZeTY1jj
· Read Only
I love this little tire calculator, put in the size and it tells you the difference in outside diameter from one size to the next, including different size rims. It also tells you what % + - your speedo will be off compared to the stock tire. Very useful
http://www.miata.net/garage/tirecalc.html
Discussion Starter · #4 ·
ok sdo I want a highway all season or close to it for mileage, but taller and slightly wider;
here is what I have fond so far
- general grabber hts 275/65/20- $207, just a little taller, same width as factory
-BF Goodrich all terrain t/a lt285/65/20 this tire is 34.7
-yokohama 37X12.5R20LT- $414 each- 36.5" tire looks like it will fit rim, do
1 - 4 of 4 Posts
