1 - 3 of 3 Posts
Hi,
I purchased some Baja Design XL-R 80 LED AUX lights for my 2014 RAM 1500.
I plan to use the HIGH beam harness as a trigger for my setup. My BD racing harness has a trigger wire, and relay already. I just need to know if tapping into the high beam harness will piss off the RAMBUS system.
The idea is that when the high beams come on, it triggers my 2 driving/combo AUX lights, and the hope is they automatically turn on and off with the high beams as oncoming traffic comes and goes.
Safe to tap the high beam harness? Same with the fog harness? I'll use that to trigger the amber 42 degree BD cornering LEDs.
Thanks
I can't answer for sure, but I would think as long as you are just activating a relay it should be OK. Only way to find out for sure is to try it.
Discussion Starter · #3 ·
That was my thinking. I emailed a BD's tech, but he wasn't sure. I think I'll phone next and stay on the line until I get confirmation it will not muck up the rambus system. As much as I'd like to 'experiment', I don't have time to deal with negative consequences.
Thanks Airforce26yrs
1 - 3 of 3 Posts
