Has anybody installed an aftermarket throttle body to there 11 RAM? If so what and did you notice any differnce in performance?
I'm glad you posted this. I was considering having my TB ported, but the more I thought about it I became somewhat skeptical of how much of an improvement would actually be seen. The internal plate remains at 80mm. Regardless of how much either side of the TB is ported, you're still limited to the opening and closing of that 80mm plate in the center. I'm certainly no expert but I assume the gains would be minimal at best. And the 85mm over sized TB seemed like overkill on a naturally aspirated truck with only an intake and exhaust.However, if you are set on a new TB, I recommend paying the bit extra and getting a cast 85mm TB, not the ported stock jobs since you're not getting any diameter gains around the throttle plate, it's still an 80mm throttle plate, they just smooth out the intake side. BBK has some problems with their TBs, so I'd recommend looking at the Arrington TB.
