1 - 3 of 3 Posts
Sounds to me like it could be an exhaust leak, first thought that comes to mind for me anyway.
Yeah, first thought is exhaust leak. Second thought is, you did get the rocker shafts installed with the not h at the proper end, didn't you? Third thought, you did use an LA cam with oil holes in number 2 and number 4 cam journals and not a Magnum cam? Also, I'd pull the valve covers and make sure the pushrods are properly seated in the lifter cups and rocker arm cups.
1 - 3 of 3 Posts
