1 - 6 of 6 Posts
I have an 04 1500 4wd. The front is leveled and I am wondering what size of tire you guys are running on your rigs. I want to go taller than stock but how much bigger can I go. Any input would be helpful. Thanks guys.
I have a 2.5" level on my 2010 and am putting 35" tires on tommorrow. I have been assured that it won't rub.
Discussion Starter · #5 ·
Its an 04 1500 sittin on the stock 20"s. No trail drivin but I will take it out in the hay fields from time to time. Any idea on brand and aspect size. Ex. (305/55r20)?
I think 275/65 is a good choice. Same width as stock so zero concerns of rubbing but an inch taller than stock (stock is 33", 275/65 is 34"). Plus, they won't absolutely break the bank. If you are in the market for a good A/T tire Cooper Zeon LTZs or Nitto Terra Grapplers are hard to beat. There are other options....285/60 or 285/65.... brand options get slim and expensive with those sizes though. You should be able to run a 295/60 or even a 295/65 but once again they are expensive. I would avoid the 305/55 myself because while it is a good bit wider, it isn't noticeable taller than stock.
1 - 6 of 6 Posts
