1 - 5 of 5 Posts
Discussion Starter #1
hello rammers. I'm a nubie so please bear with me.
last week I posted a question and now can't find it so I'll ask again.
(I probably pushed wrong button)
Can I cut the orrd wire at the tipm c6 connector AND the pkyl wire at the tipm c9 connector then tie the orrd c6 stub to the pkyl wire to the power window circuit breaker thereby making power windows usable with ignition OFF. ?? ALSO tie the pkyl c9 stub to the trailer 'always hot' wire thereby making it 'ignition hot' instead ?? (after cutting it, of course)
You can always go to your home page and click on ' Statistics '
it log's every post you've made ;)
Super Moderator
This just sounds like a bad idea
Most of this electrical system is on a Can Bus system. Not direct and monitored through the PCM so it may not work. Not having a schematic on the system I can't say for sure.
Anyway I would agree with some of the above statements that it is not the best idea especially around young children. Eons ago power windows would operate without a key in the ignition, so it must have been changed for a reason.
1 - 5 of 5 Posts
