1 - 4 of 4 Posts
Discussion Starter #1
Ok, first off it's a 2016 Ram Tradesman 2500 Crew Cab 4x4 6.7 Cummins Turbo Diesel currently running 295/70/18 Cooper Discoverer St Maxx tires on Fuel Trophy 18x9 wheels. Suspension is stock rear, Pro Comp 2 Inch leveling lift kit front for tire clearance. I have a cab-high shell on the truck. The prior tires/wheels were BFG KO2 275/70/18 on the stock 18" wheels. The BFG only lasted 16,902 miles until they were down to 4/32s. I replaced these with the above-mentioned Fuel Wheels and Cooper Tires. They are now looking a little thin so I measured and they're down to 7/32s. This is after 23,032 miles. Taking the advertised tread depth of both the BFGs (15/32s) and the Coopers (18.5/32s) I figured the miles it took to burn off each 1/32 of tread and it came out to 1,537 miles for the BFGs and 2,003 miles for the Coopers. Based on that the present Coopers tread depth I should get about 6,000 more miles before I have to replace the Coopers. This will give me almost 30,000 miles off the Coopers. I kind of like them except for two things. #1 - The Discoverer St Maxx has a sort of directional tread (for lack of a better description). What I mean is, if you're looking at the front of the truck the tread on both the tires cut across the tire from the left side going downward to the right. (see picture).
They've always pulled a little to the right since day one. I had the alignment checked and they said it's right on and they blamed the Coopers. I'm assuming that is so since the wear has been even. And, #2 - 30,000 miles isn't bad but I'd like to get a little more out of the next set. Or is that a pipe dream? Anyway, if you're still reading after all that what would you replace the Coopers with when the time comes in a couple of months or so? I do want to stay with the 295/70/18 size. Thanks.
The KO2's did have a short tread life on the heavier trucks and BFG got lots of complaints over that. I'm surprised that you only got 16k out of yours. Last December BFG put out a KO2's with a modified tire compound that should last longer on the heavier trucks. I think they are worth another shot. I think you should go with a larger tire, but thats my personal preference. Maybe someone with larger tires on their 2500 will share pics so you can get an idea of how it would look.
I would recommend a less aggressive tread design if you want to get a longer life on the tires. The new Cooper AT3 XLT All Terrain is a good option and I've been running them in the 295/70-18 10ply on my 2013 1500 for a year now. They're very quiet and smooth riding. No vibration at any speed with aftermarket wheels that are not hub centric. They have a 60K mileage warranty. I was impressed with the winter traction and the aggressive sidewall design.
Discussion Starter #4
This may be what I'm looking for. Thanks for the info.
1 - 4 of 4 Posts
