1 - 3 of 3 Posts
TLC is available.for the 2014 RAM 2500.
While the RAM 2500 with coil springs improves everyday ride, even this heavy-duty truck sags under heavy loads.
TLC adds over 5,000 pounds of lift with two 9" Goodyear® air springs that bolt-on next to the coil springs (no modification required)(never exceed GVWR or GCWR).
As with TLC's other products, your truck will be level hauling or towing even at the max GVWR or GCWR - and TLC's patented system does not interfere with the smooth factory ride.
As with other TLC suspensions, use with any external air source - a hand-held compressor, TLC's wired air compressor kit - or we recommend the WirelessOne wireless air compressor system.
Competitively priced at $499.
Please let us know if you have any questions or check out our webpage about it:
http://www.totalloadcontrolsuspensio...pring2014.aspx
Of course, TLC is available for
- 2009-2014 RAM 1500
- 2002-13 RAM 2500
- 2002-2014 RAM 3500
1 - 3 of 3 Posts
