It sounds like their is a bearing failing somewhere in the transmission. I for a second thought maybe the driveshaft lost balance or something or possibly a bad axle bearing but it sounds to me maybe a bearing in the transmission, especially since you say when you shift it into 5th gear everything is smooth as butter! So possibly a component within the transmission that has a bearing isn't spinning in 5th but does in 4th or 3rd so on.Well I had my dealer replace the torque converter and the howling was fixed and the growling/grinding is still occurring only when the engine is in eco mode. If I put the shifter into 5 it is eleminated completely. I am happy that the obnoxious howling is gone but this slight grinding noise is killing me. What other things should my dealer check, they seem to be dumbfounded and want to replace the torque converter again (they replaced original with the updated one). They also drained my rear diff took the cover off and looked. All the gears where fine and no metal shavings present in the transmission or differential, so I am lost as what todo now. Any help is appreciated thank :doh:
Brandon
