Hello Forum.
A LITTLE BACKGROUND:
I recently posted a thread called "will the ride improve". I bought a 6.4L 2500 4.10gear to pull my travel trailer. I intended to drive the 2500 as a daily driver. The 2500 was so rough and clunky that my wife would not ride in it, and it was literally making my kidneys ache (we called it the "kidney buster"). I pulled the trailer 500 miles with the 2500 (Dallas - Tulsa), and it certainly did a great job of pulling. However, even with the trailer weight, the truck was almost undrivable for comfort and gas mileage.
I am a "weekend warrior" camper. I pull about once a month and stay local around Texas and Oklahoma. Payload typically includes 2 adults and 2 kids with bikes and grills.
I am a fairly experienced trailer man. I have pulled many trailers with both 1/2 ton and 3/4 ton trucks. I have handled trailering emergencies. I have a masters degree in mechanical engineering (go sooners) and have experience with vehicle drive trains and transmissions.
So, I traded the 2500 in for a 1500 HEMI 3.92gear. That mistake cost me $7,000 in trade in value.
THE TECHNICALS:
I bought the 2014 HEMI 1500 Laramie 3.92gear - 8spd tranny 4x4 with tow package and integrated controller. I installed AirRite 1000 bags and Timbren Bushings. (see pictures attached)
From the Dodge Website that truck is rated to "safely pull" 8,673# with 1327# payload. The truck is advertised for 395HP and 410lbsft torque.
My trailer is a Rockwood Ultra Lite 8327SS travel trailer. I weighed the trailer at certified CAT scales trailer weight is 8,500# and tongue weight is 1200#. I have a Trekker weight distribution hitch. This is fully loaded configuration.
I am definitely at the limit of advertised weight. With kids and bikes I am at the payload limit. After a delicious steak dinner, maybe a pound or two over.
THE RESULTS:
I test drove the truck and trailer this weekend. I happy to report that the 1500 pulled this trailer VERY well. I aired the AirRite 1000 bags to 30 pounds which lifted the rear axle of the truck about 3". When trailer weight was applied, the truck ended up perfectly level and the Timbrens were within about 0.5" of axle contact.
I drove the rig 200 miles from Dallas through the Arbuckle "mountains" (elevation 1412 feet with some fairly steep grades). I got ZERO sway, ZERO bounce and ZERO sag. The rig felt very stable and had plenty of power. I was able to maintain 65MPH through the mountains and had plenty of reserve. I rarely use my brakes during trailer pulling. I manage speed with throttle and transmission. The temps were within normal range. Oil temp reached 250 degrees going through the steep grades, but ran normally around 220. The transmission easily and comfortably managed power between 6 and 7 gear in Tow/Haul mode. On level sections would drop into 8th gear and I was getting about 12MPG according the EVIC. The truck was very comfortable ride.
I felt very comfortable in pulling the trailer. Here is a YouTube video of the pulling at the highest part of the mountains.
(https://www.youtube.com/watch?v=_jtes7IZX84)
THE CONCLUSION:
Yes, I am definitely at the highest weight rating of this truck. However, I had to balance between a daily driver and a truck that would pull this trailer.
After I dropped off the trailer, I released the air bags and drove home in Cadillac comfort at 24MPG. I agree that the truck is at the weight limits, however, I believe this truck provides the best of both worlds (pulling, driving, comfort, mileage)
THE TECHNICALS:
THE RESULTS:
THE CONCLUSION:
