I picked up my new camper today. On the tow home I started having some temp issues. I was running mostly dry with about 4000lbs of weight. My camper is about 3800lbs dry weight. It was 73 outside and humid. I was running in T/H mode. My temps went up to about 3/4's on the gauge. About 260 I would estimate. I was running between 60-65 mph, with some moderate hills.
I have less than 58,000 miles on the truck. When I would drop down to 50-55mph my temps returned to normal. On some hill's it took about 3500 rpm to maintain 62mph while climbing them.
Am I running too hot? I am worried that when its 100 out this summer and I am loaded, I will be left over heated.
Should I have the rad flushed and a tranny cooler installed? Am I trying to push the 4.7L too hard?
Could this aftermarket grill be cutting off too much air flow?
Sorry for the large pics, the forum won't let me attach them for some reason.
I now by the time I am loaded with pots, pans, stoves, bikes and wood, and everything else, I will be close to the 6000lb capacity of the truck. Do I need a bigger tow vehicle, or just drive at 55 all the time?
