1 - 2 of 2 Posts
2016 Laramie Longhorn 2500 Mega Cab Diesel
Anyone out there experience intermittent notification, "SERVICE TIRE PRESSURE SYSTEM"? Three of the tire pressures come up fine and the right front shows "-". This happened about 15 times on a 6 day round trip to Canada from Texas. Only once did both right side tires come up blank. Goes on and off at will. Truck currently has 6k miles and I hate to take it to the local RAM dealership. My dealer (I trust them) is 150 miles away.
Check your tire pressure first. If that's good, might be the TPS sensor in the wheel. The sensors should last between 6-8 years and batteries in them go bad. You could drive 150 miles to dealership if you want, or just order a TPS replacement kit with the sensors and replace them yourself (easy to do) and save money
1 - 2 of 2 Posts
