1 - 3 of 3 Posts
Discussion Starter #1
Alright, so I'm curious if anyone else has had TPMS issues on a '16. My truck wasn't a month old and it told me I was having air problems, but upon checking my computer everything was fine. Eventually it reset itself but every now and then it crept up. I attributed it to the cold weather. But now, the weather is not cold and I'm having the same issue. I'm curious if it's software since the sensors themselves appear to work fine.
In full disclosure, I ditched the Duratracs for Open Country MTs but the pressure is exactly the same.
Luke
Power wagons require 60psi front and 65psi rear, you can deviate from this some but not much. I have heard +/- 20% is max. What pressure are you running?
Discussion Starter #3
Well, yesterday I was coming home from the hills and the PSI was 65/66 front and 67 back.
This morning back on the edge of the delta it was 59/60 front and 61 back. No lights on. I guess they are a bit high especially when I change altitude.
1 - 3 of 3 Posts
