1 - 3 of 3 Posts
0
Discussion Starter #1
I have on 03 Ram 1500 RWD with the 4.7. Just recently my transmission has began dripping fluid and is visible on the yoke connecting the output shaft and the driveshaft. Not sure if there is a weep hole or if I have a failed seal or o-ring. (It is parked on a slight hill.)
Anyone else experienced this and what was the solution?
Resident Technician
Install a new output shaft seal. If there's a groove in the yoke, you'll need to replace that as well.
0
Discussion Starter #3
Thanks for advising me on this RamTech. I appreciate the help.
1 - 3 of 3 Posts
