1 - 2 of 2 Posts
Is there a good way to test for bad transmission or transfer case I have 2 rams 1 is lifted 6 inches short bed single cab the other is a 3/4 ton 4x4
The 3/4 ton is the one with the issue it shifts hard into reverse but will not move in drive.
Fluid is nice and clean and no burnt smell
Any ideas
Thanks Mark
Sounds like a transmission issue. Transfer case only will show up when you put it in 4x4. I actually stretched the drive chain in my transfer case by using my Ram as a skidder, towing out logs! Was easy to replace, however. I also had the line pressure raised in my 545 RFE.
1 - 2 of 2 Posts
