1 - 6 of 6 Posts
Weirdest thing and I haven't seen anyone else mention it. My Check Engine light comes on all the time with every tank of gas. With the Check Engine light on, the Traction Control Off light comes on AND THE ELECTRIC CONTROL TRANSMISSION DROPS A GEAR OR TWO AND WON'T SHIFT ANYMORE. Have to stop the car and restart. Very serious safety issue. Causes me to slow down in traffic with no warning. Anyone hear about anything like this? I can not detect an action or process that triggers this. Seems totally random.
Wow that is crazy.... You have a 14 is there still warranty left on it? May want to record that bad bot doing it and take it to the dealer.
You're setting some kind of trans fault that is throwing you into limp-in mode. Go to a parts store and have them read the fault codes for you. Then post the code(s) you're getting and I can give you some more detailed advice.
You need to have codes read by a dealership, especially if you have a mopar warranty.
I stand corrected. I hadn't noticed that you have the 8-speed trans, which uses a separate TCM. 6-speeds use a PCM (which a parts store can read), but with the 8-speed most parts store scanners won't read the TCM. So you do need to have a dealer read it.
1 - 6 of 6 Posts
